XR250
- Jan 30, 2013
- 5,925
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Footnote 3 of Table 2 supports my understanding. The engineer needs to check the wood. Simpson doesn’t.ICCES_ESR2551.pdf
ssttoolbox.widen.net
Generally agree, but see below. Looks like enforcement to me. The tables provide the numbers (e.g., 12.5.1C).While there is a point where the capacity of a nail will be diminished when placed too close to the end of a beam, the NDS code interestingly doesn't enforce spacings and edge distance for nails, it only gives recommendations in the code commentary.
Those tables aren't applicable to nails and wood screws (assuming diameter < 1/4").Generally agree, but see below. Looks like enforcement to me. The tables provide the numbers (e.g., 12.5.1C).
True, the code does state that, but then fails to provide any distances for these things. Kind of like saying: "Beam to safely resist all required loads." The code commentary does however provide some good guidance. For this particular case (per OPs question), though, I don't think the commentary addresses end distance with loading perp to grain.Section 12.1.6.5: Edge distances, end distances, and fastener spacings shall be sufficient to prevent splitting of the wood.
Agreed. I'm generally hesitant using 3rd party products, but Simpson is definitely one of the better (more trustworthy) companies in my opinion.Simpson has been very responsive in the past to my questions (aim them at a "field engineer" for your area). I have been impressed at how much they internally test connectors and fasteners in various applications and they are generally willing to share data with you, even for non-standard installations.
They are but there is still a lot of fine print in their catalog that gets unnoticed and IMHO is intentional so they can sell more product.Simpson is definitely one of the better (more trustworthy) companies in my opinion.
Good call about the quarter-inch threshold. Most nails and screws don’t get that big. Anything larger and the geometry factor kicks in hard, per 12.5.1.2.Those tables aren't applicable to nails and wood screws (assuming diameter < 1/4").
