Needhelp securing nuts to a metal plate
Peter Glus
9
I have a small plate that I want to move up and down by turning a threaded rod. The plate is not thick enough to tap it, so I was doing some research and found sleeve nuts. However, i want the plate to hold forces up and down, and sleeve nuts seem 1 directional. Ideally, if they could make a 2 piece sleeve nut that locks onto the plate that would be ideal. Any help out there? This in advance
Puit the nut underneath and glue it or weld it or braze it to the plate?
We don't have any details here???
OP
Weld a flange nut to the plate. How thick is the plate. A quick sketch would be helpful.
What type of load. FBD is usefull
Problem with welding is the plate is aluminum and the nut is ss
Also, axial load both up and down is 100#
tap the hole ?? hold the nut in place whilst you tighten it ??
There seem to be plenty of solutions ... inside and outside the box ... ??
I think I might try to get a weld nut with a large flange and bolt the flange
Rivnut seems less strong, but I could be wrong
Ummm. Drill three holes in a piece of steel. Tap the center one. Bolt or rivet it to the plate with the other two....
Mike
Mike, silly of me...i think that's the best solution. Many thanks for the clarity, as this should be stronger that rivet nuts.
AI Overview
+1
What is the Nut Factor and How Does it Affect Torque?
The force on a screw with a nut can be calculated using formulas that consider the torque, friction, and other factors.
Torque
  • T = kDP
    Estimates fastener torque, where T is torque in newton-meters, k is the coefficient of friction, D is the fastener diameter in millimeters, and P is the desired tension in kilonewtons
  • T = KFiDb
    Calculates bolt load based on applied torque, where K is the torque coefficient
Lead screw
  • (F) = K x C X 106 x d4 /D2
    Calculates the maximum column load, where F is the load, K is the end support factor, C is the material factor, d is the root diameter of the screw, and D is the length between the nut and the support bearing
  • (T) = (F x L) / (2 x M x E)
    Calculates the torque to move a load, where T is the torque, F is the load, L is the lead, and E is the efficiency
Bolt break force
  • Multiplying the ultimate tensile or yield by the cross sectional area of the bolt gives the actual force to failure
Tensile load
  • The tensile load a fastener can withstand is determined by the formula P = St x As
