reverbz
- Aug 20, 2024
- 81
Hey Guys,
Designing a job with open web steel joists for the first time(as you may have seen from a previous post) and was wondering how you handle a couple things on mechanical unit support. Do you call out the joists supporting these as girders no matter what the weight of the mechanical unit is? Or do you have a limit you think a regular joist can handle? Will the manufacturer verify if a girder is needed if you give the loads on the drawings?
Also, do you call out your mechanical supports on a typical detail assuming the weights are similar and just use worst case? That's what I'm planning to do as of now.
Thanks again for the help!
