NX2312 Sketcher and Drafting - Approximate Dimension Symbol
hmichel
Aerospace
Jan 7, 2014
I am currently using NX2312. In both sketcher and drafting (though this is the most important in the drafting application I suppose), when dimensioning two objects that have decimal places beyond the dimension limit, the approximate (double tilde) symbol automatically appears before the dimension. Is there a way to remove this symbol? In my case, I am dimensioning objects with very abnormal positioning, so it is not desirable to increase the number of decimal places to try to eliminate this symbol, and in this case the number of decimal places could be increased to 6 and the approximate symbol would not disappear.
Example image shown below:
If there is a way to disable this behavior in the customer defaults I would be interested in those settings as well. Thanks!
-H
Hello, just pinging the thread again to see if anyone had any insight into the issue described above.
I am not using the new sketcher yet.
In Drafting, are these symbols still visible if you de-activate the sketch ?
Toost is correct, once you finish the sketch in the drafting, the symbol should go away. I dislike how these dimensions behave so differently in the drafting application vs the older sketcher. But they should go away once you finish the sketch and pan around.
