nedians
- Mar 8, 2001
- 28
I want to know why working loads are used in case of foundation design while the entire structure is designed on ultimate. whats the reason behind this.
Q-1 .. why the min steel requirement in foundation is 0.81% whats the reason behind this?
Q-1 .. whats steps u recommend when designing a footing size to support loads on 2 columns ( live load = 200 & 300 ,dead load 200 & 100 on both columns respectively ) which are spaced at 30ft clc . allowable soil pressure is 6k/ft.
