“Compenent” elements seen as “ProductDocument” in CATIA VBA 1
MsuMsu
14
TR
I have a problem. I can import feature types in catia vba with the following codes
Set document1 = CATIA.Documents.Item("Product1.CATProduct")
Set products1 = document1.Product.Products
For i = 1 To products1.Count
MsgBox TypeName(products1.Item(i).ReferenceProduct.Parent)
Next i
but it also shows "Compenent" elements as "ProductDocument". If component is, I want to make a separate operation.
How can I find out that an element is a "Component" ?
Just thinking... If you search for the file name of that component and compare it with the product above, you will be able to know if this is a component or a product... If this is the solution please share the code.
Eric N.
Code:
for each prd in products1
  if prd.ReferenceProduct.Parent.Product.PartNumber <> prd.PartNumber then
   ... this is a component
  end if
next
