One of the 11kV, 3000kW motor was recently overhauled in an outside workshop which is not part of the plant. The workshop did not have the testing at 11kV. Hence they have tested the motor at a reduced voltage level of 3.3kV. The testing was found OK.
When the motor was sent to site, they have conducted the motor solo run. During the solo-run some abnormalities were noticed as below.
Motor total axial float showing 11mm
Carried out solo run test for one hour under observation found full axial movement of the motor to the pump side and we found magnetic center 10mm
Not getting proper magnetic center during solo run test (It is not in the center 5.5mm)
Slightly higher Vibrations, but within the acceptable limit.
Most of the problems are mechanical in nature. As I am an electrical person, I have some difficulties in understanding the exact problem. Can anyone throw some light on this issue or share their past experience of similar nature?
Also how the problem can be solved?
