istruct1980
- Jun 29, 2019
- 19
Im just curios for designing of steel connection to rc column for long span i beam. i designed several times for canopy steel beam to rc column connection for canopy several times but those are at most 5m span.
Im wondering if there area any other considerations for designing of the long span 14m canopy i-beam to rc column connection. this long span canopy steel beam is carrying only roof(trusses,roofing)
will it be enough for just the simple and typical i-beam welded to base plate and base plate bolted to rc column?
do you have exactly same design computations for this?
