walterbrennan
- May 21, 2005
- 50
It seems clear that the 15 psf partition load, as required in IBC 2015 section 1607.5 is considered a live load... at least, the commentary appears to present it that way, when it states, "This partition allowance is included under live loads..."
--- What's less clear is whether or not this live load should be lumped together with the ordinary occupancy live load (e.g. office) BEFORE the live load reduction factor is applied, or AFTERWARD.
A quick look at the live load reduction provisions in section 1607.10 yields the following: "Except for uniform live loads at roofs, all other minimum uniformly distributed live loads, Lo, in Table 1607.1 are permitted to be reduced..."
--- Without seeking to be legalistic, it is probably worth noting that the partition load is not, in fact listed "in Table 1607.1"
I'm not seeking to instigate an argument, based strictly on logic, opinion, dogmatic past experience, etc. Rather, what I'm seeking is an actual published opinion, from a trustworthy source (e.g. ICC, ASCE, etc.) which might provide clear direction on whether or not the 15 psf partition load was ever intended to be included in Lo.
Can anyone offer any such reference...?
