joecampbell
so the international code (504.4) says you cant be more than 150 psi. got any good exceptions, ie can i call this water heater not a water heater and instead a pressure vessel.
the tank is rated to 200psi but due to the imc getting a 200psi relief valve seems likely to be impossible.
is using a apollo 500 series valve not a good idea.
