2018-2019 line color format template
Mandrill22
113
I'm running SolidWorks 2018-2019.
I have a few lines in my sheet format that are appearing grey when I go back to edit sheet. I updated the line color to black and it appears black when I go back to editing the sheet.
Then I create a new drawing with the same template and the lines are grey again. I checked to make sure it is referencing the updated template and it is. Any idea what the problem could be?
Side note, when I create a new drawing, how do I get SolidWorks to prompt me to select a template, rather than just selecting the default?
Check your color settings. Fully defined lines can have a different color than undefined lines.
Also check help in settings for template prompt.
