RobertHasty
I came across a hydraulic valve with 205 VDC coil recently.
The coil has a connector with rectifier mounted on it. That means that the voltage applied to the coil is 230 VAC.
I am wondering, why not use an AC valve with 230 VAC coils instead of valve with 205 VDC coils?
