edendebrock
Industrial
We have been getting gears made from this alloy. We are starting to see failure not on the gear teeth but on the bearing journals. In the past we have been using 8620 or 4320. Does anyone have any expreience with these different alloys. The application is for hydraulic pumps and motors.
We case harden and oil quench followed by -100 F treatment.
The case is .04 to .05 deep after grind. THe surface is 58 to 62 Rc
We do not have a microscope so, the observations are with reduced magnification. The surface seems to be flaking and there is a dullness to the area were the bearings roll.
We are using needle roller bearings.
