Hello Everyone!
I am trying to figure out how to connect a 24VDC NPN Proximity Sensor to a 230VAC contactor with 24VDC coil. I need the contactor to turn ON/OFF with the sensor signal. I have followed the below wiring diagram but my attempts have been unsuccessful (The contactor does not switch ON/OFF with the sensor signal). Should i use a relay to amplify the sensor signal? Both sensor and contactor are in perfectly good working condition. Any help will be greatly appreciated!
