Jboy333
- Jun 29, 2006
- 25
We're working on a project with a 1/2" square torsion rod that is being used to act as a variable spring by moving a slider with a square hole in it up and down the length of the bar to change the effective length.
We're needing a minimum yield strength of 260 ksi for our application. Can anyone please recommmend our most cost effective option for a part like this?
The part is about 10 inches long with about a 5 inch leg at a right angle where the load is applied.
We were originally trying to use a heat treated 4140 steel, but have had a hard time getting consistent results (and are probably asking 4140 to do too much for us). In a previous post some people had suggested 4140H, but nobody seems to carry it, and because of that, those that do carry it charge an arm and a leg. We're looking to be as cost-effective as possible.
Thanks in advance for your advice!
-Jesse
-Jesse
