Manuel Pimenta
In my component database I have a few components that are constructed via design tables.
These components are used over and over again in the projects, with very little variation in relation to the design table standard.
After the project is done, the next step is to make 2D drawings of each component. Right now this is done from scratch, using as start point a drawing template with only the title block.
What i would like to do is have in the database a 2D drawing already prepared, with the required views and dimensions. The drawings will be linked to the database components.
Does anyone know if is possible to have some kind of connection between drawing and CATPart so that everytime the CATPart is instantiated in a new project, the drawing would be automatically called together? I've seen something like this in Siemens NX.
