2D Exchange
phillpd
GB
NX 3.0
I have a fully loaded assembly open, and are using 2d Exchange. Simply to create a flattened part file.
However, the resulting part file has geometry missing. It appears that some of the assembly components are not being loaded.
I'm guessing it's to do with the load options, but not having much success resolving the issue.
Specialty Engineered Automation (SEA)
a UGS Foundation Partner
I'm guessing that you're going to be right there it will be pointing at or using some default load options that don't load the assembly.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
