2D Spiral
dbeiter
1
I am looking for a quick easy way to draw a 2D spiral. The outside diameter is .4, with a .002 step. I am using this for a tool path.
thanks
Do you need to have a spiral sketch? You can create a spiral using the coil feature, in the "coil size" tab you can select spiral from the type menu.
