ThePunisher
- Nov 7, 2009
- 384
I would like to throw this question as all single phasing literature I read always presents blown primary fuses.
What if:
I have step-down transformer 69-13.8 kV and primary is DELTA protected by primary fuses and secondary WYE-Solidly grounded and is also protected by fuses (typical in a small distribution utility.
If one phase of the three phase 13.8 kV secondary power lines, is open-circuited (by a blown secondary fuse or physically cut), will the single phasing condition (2 lines operation) results to sufficient primary current to trip the upstream 69 kV primary protection relay's overcurrent element?
What if: The one phase conductor of secondary 3 phase lines (before the line side of secondary fuse) cuts and hits ground. Will the primary 69 kV protection relay trip due to line-to-ground fault?
Thank you all, this is also related to one post I made earlier ("cause of trip query")
What if:
