XR250
- Jan 30, 2013
- 5,294
I have a residential project where the existing front porch slab/paver system is to be overlaid with 3” concrete spanning 3’-4”. I have no way of verifying the existing slab capacity, however, the slab appears to be 3” thick with 1” of mortar and full-depth pavers. It vibrates more than expected when it is jumped on. I have run the numbers and it appears that a new 3” slab with #4 @ 18” O.C. meets the demand using 1” bottom cover. The ends of the new slab will be supported by the existing perimeter foundation. There is a roof over this area. Is there any practical issue with specifying a 3” slab? Seems thin. I will have the contractor provide a line of temporary shoring under the existing slab.
