Looking for some inf9ormation regarding 3 winding transformers and a question i have.
Looking at a design which requires a 3 winding transformer. 66kV on primary, 11kV on Secondary and 415V on tertiary. The 66/11kV winding is 5MVA to power a specific bit of plant, however the 66kV/0.415 tertiary winding is for ancilaries such as auxiliary supplies - in the order of 100kVA.
The tertiary winding needs to be permanently energised to power the auxiliaries and the control system. The main power winding will be as an when required fo the primary/secondary winding will not be energised 100% of the time.
Is there a risk that the 66kV/0.415V tertiary winding shall not operate effectively when the main primary/secondary winding is operational? is a 66/11/0,415kV transformer feasible?
Ive had a look through the forum history and its not that clear.
