We are working on a project installing a submarine power cable. It has been suggested that we install load breaks in the manhole where the cable transitions from submarine cable to terrestrial cable to allow isolating the two segments for troubleshooting in the future.
My first inclination was to make this transition inside a separate watertight splice case for each conductor (total of three) or similar with hot/cold shrink splice methods. The concern raised is reterminating the cable whenever the splice is opened with require cutback of the conductors and eventually consume whatever slack is placed in the manhole at installation.
My concern is using a load break in an environment that could potentially be sea water flooded long term. Reading thru the spec sheets I see the term submersible but don't see any specs on how deep or how long.
Thoughts, suggestions, ideas welcomed
Larry
Larry Mackey
Larry
Larry Mackey
