hi,
guys, i need your help.
i have a terminal, there is 3 pins in it and they are made of copper core wire with jacket 446 stainless steel.
the terminal was returned from one customer, and it was found that one of the pins was broken. on the broken pin's surface , i found serious corrosion as the attached photo shows.
BTW, the terminal was used in refrigeration compressor.
can anyone give me some suggestion why this could happen, and how? also, any good ways to prevent it to happen?
thanks in advance.
thanks in advance.
