480v Outlets
Cow44
5
I am having three 480V outlets installed but due to power limitations only one of these outlets can be used at a time. Can anyone give me any suggestions on how to ensure that we use only one at a time? Thank you!
Use different configurations. Use one configuration for the outlets and another for the utilization equipment. Supply only one adapter.
I am away from home and can't look up specific devices but at 120?208 I would consider using twist-lock receptacles and straight blade cord ends on the equipment. Then supply only one adapter cord to go from twist-lock to straight blade.
Another option is to have a breaker panel with three breakers. Mount a slide bar on the front of the panel with notches to fit the breaker handles. Space the notches so that when an breaker is turned on, the handle fits into a notch and the bar prevents any other breaker from being turned on. If approvals are required, consult with a panel builder who has supplied breaker based bypass panels for UPS installations.
Bill
"Why not the best?"
Jimmy Carter
Thank you for those suggestions!
This is what "Kirk Key Interlocks" are for as well. 3 locks, one key and the key cannot be removed if the lock is unlocked so you can never unlock more than one at a time.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> faq731-376
