Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Contact the manufacturer , go to their web sites ton of informationGood afternoon, does anyone have a profile of the pulley tooth for the gates power grip 5gt belt, ours has crumbled, and during the design there were problems taking into account the power reserve.
The most interesting thing is that there is very little information on 5gt specifically, even on the Gates website. But most belt drives for machine tool spindles use these belts. The spindle manufacturer can't help either, as they have ready-made tooling for pulleys, and only the profile name is indicated in the documentation for assembly. We found several options on 3D modeling sites, but with a more detailed drawing, the teeth "run in".Contact the manufacturer , go to their web sites ton of information
There is a two part dental cast. Take a cast of the belt. Inspect and record on optical comparator.The most interesting thing is that there is very little information on 5gt specifically, even on the Gates website. But most belt drives for machine tool spindles use these belts. The spindle manufacturer can't help either, as they have ready-made tooling for pulleys, and only the profile name is indicated in the documentation for assembly. We found several options on 3D modeling sites, but with a more detailed drawing, the teeth "run in".
