ThStructuresGuy
- Nov 14, 2017
- 7
I've got a project where they cored four drains in the wrong location and they need to infill. The cores are 6" in diameter and the slab is a 4 1/2" Normal Weight Concrete slab on 2" Composite Deck (6 1/2" Total Thickness) that will receive a 2" topping slab. Has anyone had to do a similar repair before? I was thinking of using a 68 mil sheet attached with screws below the opening and then filling the opening with non-shrink grout.
