Hi
I need to install a replacement 85m 4" riser to handle a mixture of sea water, hydrocarbons and sand. The choice is between 6Mo and Monel 400. The pump discharge spool is 6Mo and the piping it eventually connect to is Monel 400.
I know 6Mo has better corrosion resistance to salt water but does it have a better erosion resistance?
Do I need a insulating gasket between the two materials?
Thanks in advance
Thanks in advance
