720026: Part is not suitable for use as a component of an assembly
Ehaviv
Computer
Jul 2, 2003
1,012
Hi
I get this error in a journal that open a parasolid file.
Do someone understand tihs error?
Thank you in advanced.
What happens if you open the same file interactively ?
Tomas
I haven't the journal in my computer.
and I'm out of my work place for a week.
Meanwhile I ask myself what matter not
Suitable. Is it graphics issue?
How does your code "open" the parasolid file?
In interactive NX, when you go to file -> open and change the file type to parasolid, NX will create a .prt file in memory and add the geometry from the parasolid file. I don't think you can do assembly operations with this part file until it is saved to disk; a journal would have the same limitations.
www.nxjournaling.com
Hi Cowski
Your explanation is rights and clear.
As I remember the journal use UFPart.open.
And maybe the ps file is corrupted.
Thank you very much.
If your code is trying to add the parasolid file directly as a component of an assembly, that could also be the source of the error.
