pwrengrds
- Mar 11, 2002
- 232
What is your take on the rating provided. The system is connected to a 13.8kV ungrounded system, the PT's are PTG5-1-110-842F, see attached spec sheet. The PT's are connected phase to ground, the max system voltage rating is 15.5kV.
Is the PT with the primary voltage rated at 8400 volts okay to operate at 13800 volts if ground fault occurs?
Does the fault need to be cleared without delay?
Should the PT not be installed on an ungrounded system?
David
David
