A 3" propane makeup line to refrigerant surge drum has a ¾" PSV. Inlet line is also ¾". This inlet line to PSV is vibrating. It is reported that the propane makeup line is not vibrating. Now the question is as this is normally no flow line, what is causing vibration? The vibration as per Energy Institute guidelines is within Concern zone.
Can you please share your experience on the causes of PSV inlet lines vibrating without any popping up event?
