What would you guys think of a large city (like Chicago) designed entirely around a main-tie-main approach? No secondary networks either.
A few down sides I see in networks:
1) The loss of more than one or two feeder cables under peak load conditions can result in the entire network needing to be shut down in that the remaining cables and transformers overload. This overloading can weaken cables making future failure most likely.
2) A ground fault with a stuck network protector (which is rather common) subjects cables to full line to line potential resulting in unnecessary dielectric stress which could lead to future failures.
3) Short circuit current is obscene
4) Relying on "burn clear" techniques greatly increase the incident energy- possibly damaging other cables/equipment in the vault- and releasing vast amounts of smoke and fire sometimes entering the basements of building producing high CO2.
5) The loss of any one transformer without causing a primary feeder breaker to open results in unnecessary stress on reaming equipment during other equipment outages increasing the odds of failure now and down the road.
Yes there is the advantage of maximizing assets while providing superior service continuity in the short term- but the long term has me pondering what I consider to be a self fulfilling prophecy.
Just thinking...
Just thinking...
