9909032ma
- Jan 5, 2016
- 3
Dear Sir
I am going to analysis the pile deflection on SAP2000 v17 for my fyp research. Firstly, i am using ALLpile to calculate the py curve, Tz curve and Qz curve and I insert the curve by [Define] --> [Section Properties]--> [Link Support Property] and then i choose [multiplastic] and enter such curves into U1(Z-direction) U2(X-direction) and U3(Y-direction) respectively. On the other hand, I insert a load case as [non linear]. After that i carried out the analysis. However, the deflection is highly different from the value that shown on ALLpile. Would anyone can help me? Thank You
I want to add the py curve as similar as the link shown below
My set up procedure
william
My set up procedure
william
