ss676420
- Feb 21, 2012
- 1
I am trying to run an input file. But when I monitor the job there is a warning that I can't find out why!! it is:
The *user defined field option has been used with the stavev array dimensioned to zero since the *depvar option is not used with this material. Consequently, defining statev entries in usdfld will cause code execution errors.
Has anyone had this problem before? Feedback would be really appreciated
Thanks a lot.
Thanks a lot.
