Jun 27, 2011 #1 Nella95 Mechanical Nov 21, 2005 400 0 0 US I know there's a way to wrap a decal to a solid feature, but what's the best practice for wrapping a decal/solid feature to an assembly?
Jun 27, 2011 #2 Eltron Mechanical Mar 3, 2005 2,459 0 0 US Are you talking about a decal that you created as a solid part or adding a decal in PV360? Dan http://www.eltronresearch.comDan's Blog Upvote 0 Downvote
Jun 27, 2011 Thread starter #3 Nella95 Mechanical Nov 21, 2005 400 0 0 US The 'first' instance you said however, I can do either. Upvote 0 Downvote
Jun 27, 2011 #4 Eltron Mechanical Mar 3, 2005 2,459 0 0 US If you can do either I would suggest the PV360 route. Just go to PV360/Edit Decal then browse to the image that you want to use. Adjust your mapping settings to make it look the way you want, and you should be home free. Dan http://www.eltronresearch.comDan's Blog Upvote 0 Downvote
