Oct 3, 2019 #1 MadhuBR Structural Mar 22, 2018 2 0 0 IN Is there any formula for A325X bolt length calculation or its same as usual bolt length calculation
Oct 3, 2019 #2 Lomarandil Structural Jun 10, 2014 1,859 0 36 US Bolt length -- as in which length bolt to order? Same as any other structural bolt, with the added step of making sure the shank length is adequate to achieve an X condition (depending on number and thickness of plies, etc.). ---- just call me Lo. Upvote 0 Downvote
Oct 3, 2019 #3 azcats Structural Oct 17, 1999 688 0 16 US And depending on your relative ply thicknesses, the bolt may only be 'X' if installed in one particular direction. Upvote 0 Downvote
Oct 3, 2019 #4 RWW0002 Structural Jun 10, 2011 314 0 0 US Look for "Specifying Bolt Length for High-Strength Bolts" by Charles Carter https://www.aisc.org/Specifying-Bolt-Length-for-High-Strength-Bolts#.XZYydGZOmuA This is a useful guide for bolt detailing in general and includes some charts that should help you out. Upvote 0 Downvote
Oct 3, 2019 #5 JLNJ Structural Oct 26, 2006 1,986 0 0 US I avoid specifying X bolts (threads excluded from the shear plane) due to the real possibility of a bolt mix-up on site. Upvote 0 Downvote
