I have the following piece of code:
but I get the following error:
Data at 141968 locations expected. Data at 17746 locations provided. Element data request failed. Element type is C3D20R. Data at 8 integration points per element expected
elLabels is a list with 17746 items and damage is a tuple list with 17746 items but each item has 8 values (one for each integration point) e.g. [(x,x,x,x,x,x,x,x) , (x,x,x,x,x,x,x,x), … ]
Thus I provide abaqus with 17746 element labels and 17746 * 8 locations (141968 data points in total as asked) so I don’t see why I get the error.
I have tried a list of lists instead of a list of tuples but the same error occurs. I suspect is merely an issue of using the correct datatypes but the Abaqus documentation seems severely lacking.
The script works fine for odb files with C3D8R elements which have 1 integration point. I then provide the same elLabels list and damage list but then each tuple only has 1 value (e.g. [(x, ) (x, ), … ] ) which works fine.
Do you know how I can import my data into the elements integration points?
Kris
Python:
from abaqus import *
from odbAccess import *
from abaqusConstants import *
import visualization
import fileinput
import os
import shutil
import numpy as np
def tupled_list(mylist,n):
'''group every n elements of the list into a tuple '''
return list(zip(*[iter(mylist)]*n))
# Open odb
odb_filename = 'AbaqusResults.odb'
work_directory=os.getcwd()
odb_filepath = os.path.abspath(os.path.join(os.getcwd(),'..','outputs',odb_filename))
my_odb=session.openOdb(name=odb_filepath,readOnly=FALSE)
# Automate the proces of reading the step no matter what its name is
StepNames=(my_odb.steps.keys() )
lastStep=( StepNames[-1] )
# Automation of an instance naming (in the same way)
AllInstances = (my_odb.rootAssembly.instances.keys())
MyInstance = ( AllInstances[-1] )
SubmodelInstance=my_odb.rootAssembly.instances[MyInstance]
# Get dataset containing element labels and calculated quantities in here from text file
dataset = np.loadtxt(os.path.join(os.getcwd(),'AbaqusDataInput.txt'),delimiter=',')
# List of all element labels
elLabels = dataset[0,:].astype(int).tolist()
# Count the number of integration points for a single element
gausspoints = elLabels.count(1)
# Get damage data from dataset and format into a list of tuples, tuple length depends on number of integration points for eache element
damage = tupled_list(list(dataset[1,:]),gausspoints)
damage = [list(elem) for elem in damage]
# Remove duplicates from elLabel list
elLabels = list(set(elLabels))
for i in range(len(my_odb.steps[lastStep].frames)):
new_field_damage = my_odb.steps[lastStep].frames[i].FieldOutput(name='Damage',description='Damage sustained after one repitition of the loading history', type=SCALAR)
new_field_damage.addData(position=INTEGRATION_POINT, instance=SubmodelInstance, labels=elLabels, data=damage)
my_odb.save()
my_odb.close()
Kris
