I have build a contact simulation (surface to surface, hard contact) in Abaqus in which a concave part is pushed against a convex part by a simple displacement along the U1 Axis. The main goal is to get the contact force. The result is quite fine, but I've got two problems.
1. It seems like the History Output for 'Contact Normal Force' (when selecting your contact surface as the set of interest) is adding up every single force of each node so the result is a force magnitude very much higher than you see in the field output. Is there a way to get a an average force applied on the surface?
2. I dont quite understand the difference between Reaction Force and Contact Force. In my result, the Contact Force is 'correctly' applied and displayed (by concerning the contact area), but the concave part which is the part displaced does not have any Reaction Force at its contact surface, just somewhere in the center of the budy. This is strange because the force is built up in the contact area but I dont get a Reaction force there.
Can someone help me with those issues?
