Abaqus Error
Naman Verma
Student
IN
I am putting a crack of 5mm in a rectangular model and using XFEM module to define the crack. I am getting this warning continuoulsy.
***WARNING: MAPPING OF THE GENERATED NODE 397 TO THE CLOSEST MODEL ELEMENT
1997359 IS NOT SUCCESSFUL -- THE NODAL ISO-COORDINATES ARE
-1.0000, -0.27577, -9.4493. THIS NODE(-0.99555, -50.634, -2.7550)
LOCATES ON THE FIRST FRONT END SURFACE.
***WARNING: MAPPING OF THE GENERATED NODE 396 TO THE CLOSEST MODEL ELEMENT
1997365 IS NOT SUCCESSFUL -- THE NODAL ISO-COORDINATES ARE
-1.0000, -0.64900, -9.8654. THIS NODE(-0.87355, -50.666, -2.7550)
***WARNING: MAPPING OF THE GENERATED NODE 398 TO THE CLOSEST MODEL ELEMENT
1997353 IS NOT SUCCESSFUL -- THE NODAL ISO-COORDINATES ARE
-1.0000, 0.11232, -8.9792. THIS NODE(-1.1164, -50.599, -2.7550)
***WARNING: MAPPING OF THE GENERATED NODE 399 TO THE CLOSEST MODEL ELEMENT
1997347 IS NOT SUCCESSFUL -- THE NODAL ISO-COORDINATES ARE
-1.0000, 0.51708, -8.4555. THIS NODE(-1.2361, -50.560, -2.7550)
***WARNING: MAPPING OF THE GENERATED NODE 400 TO THE CLOSEST MODEL ELEMENT
1997341 IS NOT SUCCESSFUL -- THE NODAL ISO-COORDINATES ARE
-1.0000, 0.94029, -7.8789. THIS NODE(-1.3543, -50.516, -2.7550)
***WARNING: MAPPING OF THE GENERATED NODE 401 TO THE CLOSEST MODEL ELEMENT
-1.0000, -0.61629, -7.2499. THIS NODE(-1.4711, -50.469, -2.7550)
Please help me how to avoid this or what can be the reason of this warning
Try extending the initial crack geometry a bit beyond the model. You may also have to adjust the mesh a bit so that it's not perfectly aligned with the initial crack - sometimes it might be necessary to use an unstructured mesh.
