Hi everybody,
I am modeling a coupon test in which the end of the specimen is pulled to a certain displacement. I am using the explicit solver and I used amplitude to define the displacement. But when I did the analyses the output showed that the specimen wasn't pulled to exactly the final displacement that I specified. for example I defined the final displacement as 5.16mm but Abaqus applied only 5.142mm. I even used the time points to write the output at exact time points and also added some additional time with fixed displacement at the end of the amplitude. But they did not work. I appreciate it if you could help me to find the source of this error and how can I handle it?
My amplitude
0 0
0.1 0.1
0.2 0.2
0.3 0.3
0.4 0.4
0.5 0.5
0.6 0.6
0.7 0.7
0.8 0.8
0.9 0.9
1 1
1.2 1
My amplitude
0 0
0.1 0.1
0.2 0.2
0.3 0.3
0.4 0.4
0.5 0.5
0.6 0.6
0.7 0.7
0.8 0.8
0.9 0.9
1 1
1.2 1
