StefBene
- Sep 2, 2020
- 11
I'm running a simulation of a bending test of a particular beam, I have a problem with the analysis time. The analysis used is the explicit dynamic, the test is simulated in about 5 seconds otherwise it would take too long. The kinetic energy is less than the internal one so there should be no relevant dynamic phenonemes, the problem is that the various outputs show some fluctuations in the trend. There is a method to eliminate these fluctuations that does not lead to an increase in analysis times which are already long. I put the output load - vertical displacement so you can see the problem.
thank you so much
thank you so much
