Abaqus Explicit parallelization
Bayram2014
Geotechnical
FR
Dear all,
I have usually run abaqus standard in parallel with the classical cpus = option.
Today, I am trying to do the same for an explicit computation.
I run with:
abaqus job=myjob cpus=2
and I got :
mpirun: Warning one or more remote shell commands exited with non-zero status, which may indicate a remote access problem.
I do not have this problem with abaqus standard which runs fine with the required cpus and even gpus.
Thanks a lot for anu help.
Bay
Which OS do you use and how do you submit this job - any nonstandard machines like cluster, server with remote access and so on ?
I have tried on 3 different dell machines with 16, 40, 64 cpus respectively. I am not on a cluster.
Did this error message contain any additional information or just the text cited in your first post ? Or maybe log files were generated and explain some details ?
This is my log file. Please notice that When I run abaqus standard everything is fine.
Abaqus JOB expl
Abaqus 6.14-5
Abaqus License Manager checked out the following licenses:
Abaqus/Explicit checked out 12 tokens from Flexnet server lic-abaqus-rech.ensam.eu.
<91 out of 400 licenses remain available>.
Begin Analysis Input File Processor
Mon Jul 5 14:41:17 2021
Run pre
Mon Jul 5 14:48:01 2021
End Analysis Input File Processor
Begin Abaqus/Explicit Packager
Run package
Mon Jul 5 14:48:07 2021
End Abaqus/Explicit Packager
Begin Abaqus/Explicit Analysis
Run explicit
Host key verification failed.^M
Mon Jul 5 14:50:58 2021
Begin State File Translator
Run state
End State File Translator
Begin Selected Results Merger
Run mergeSel
End Selected Results Merger
Abaqus Error: Abaqus/Explicit Analysis exited with an error - Please see the
status file for possible error messages if the file exists.
Abaqus/Analysis exited with errors
Try running this with thread-based parallelization instead of MPI-based one - add this command:
mp_mode=threads
Thanks. it works with this option.
Hi and sorry to join the party so late. I've had my own fair share of parallelisation errors, the last one being "domain decomposition error":
I submit my model to the cluster with 5 cores, parallelisation in 5 domains, dynamic load balancing=off (because I have a job restart), mp_mode = threads. It used to work just fine until I defined many surface-surface soft contacts in my model.
Anything very wrong I'm doing here? I don't know how to change to .env files on the cluster, I have sent a separate request to our team for this.
Thank you!
Did you try doing what’s suggested in this error message ? If it doesn’t help then you may have to redefine some of these contacts as they seem to cause problematic overconstraints.
Thank you FEA Way,
I have no idea how to do this, zero experience with overwriting settings using the .env files. I tried: can't find where this variable is and I don't know how to modify it. What does "set to ON" mean? Do I write XPL_LINK_NOMERGE = ON? Or = True?
Abaqus could make our lives much easier...
Konstantinos
Update: loop parallelisation (instead of domain) seems to work, although less efficiently. If anyone has a better way of parallelising (with domains) using the .env settings above, please advise! :)
