I am currently implementing an Abaqus VUEL for a coupled displacement-nonlocal damage simulation.
So in principle I have an additional coupled field, which describes the "nonlocal" material damage.
My VUEL is working so far, but certain aspects of the VUEL interface and simulations involving VUELs are still unclear to me.
1) I am using the displacment dofs (1-3) and the temperature dof (11).
The temperature dof is abused to simulate the field of nonlocal material damage.
This seems to work both
in
and
simulations. For both step types, dof 11 is updated. This is also inline with the documentation. So what is the difference between those step types for a VUEL?
As far as I can tell, in the latter type the simulation terminates if the "temperature" rate is excessive -- which is annoying. I couldn't find any option to disable this termination.
2) For Abaqus/Standard UELs, Element SDVs can be exported to the .fil file. This seems to be impossible for VUELs. How can I actually export VUEL SDVs to any output file?
3) Kinetic energy: For simulations involving VUELs, the kinetic energy seems to be completely wrong. For me, it is just oscillating towards 0 with a small amplitude (~1e-2).
According to the documentation (2024), I cannot compute and update the kinetic energy for a VUEL.
So how is it actually computed?
Any help is appreciated, thank you very much
in
Code:
*DYNAMIC, EXPLICIT
Code:
*DYNAMIC TEMPERATURE-DISPLACEMENT, EXPLICIT
Code:
***WARNING: Element output to the results file is not supported for user
elements.
Code:
Sample output:
STEP TOTAL WALL STABLE CRITICAL KINETIC TOTAL
INCREMENT TIME TIME TIME INCREMENT ELEMENT ENERGY ENERGY
0 0.000E+00 0.000E+00 00:00:00 8.897E-06 541 1.500E-05 1.500E-05
Results number 0 at increment zero.
Output Field Frame Number 0, of 100, at step time 0.000E+00
1124 1.000E-02 1.000E-02 00:00:00 8.897E-06 541 1.193E-01 -6.728E-02
Results Number 1 at step time 1.00006E-02
Output Field Frame Number 1, of 100, at step time 1.000E-02
2248 2.000E-02 2.000E-02 00:00:01 8.897E-06 541 2.978E-02 -2.554E-01
Results Number 2 at step time 2.00011E-02
Output Field Frame Number 2, of 100, at step time 2.000E-02
3372 3.000E-02 3.000E-02 00:00:02 8.897E-06 541 6.613E-02 -5.715E-01
Results Number 3 at step time 3.00017E-02
Output Field Frame Number 3, of 100, at step time 3.000E-02
4496 4.000E-02 4.000E-02 00:00:02 8.897E-06 541 2.451E-02 -1.004E+00
Results Number 4 at step time 4.00022E-02
Output Field Frame Number 4, of 100, at step time 4.000E-02
5620 5.000E-02 5.000E-02 00:00:03 8.897E-06 541 4.797E-02 -1.547E+00
Results Number 5 at step time 5.00028E-02
Output Field Frame Number 5, of 100, at step time 5.000E-02
6744 6.000E-02 6.000E-02 00:00:04 8.897E-06 541 7.959E-02 -2.192E+00
