Abaqus How to show the coordinate system of beam elements in visualization window?
Fblthp
Hi all
For beam elements, I heard that results directions (such as U1\U2\U3) are given in the assigned beam section orientation (please confirm me this). This coordinate system would once display while I assign the beam section orientation to any set in property window. Now I want to show them in visualization window, how can I do that?
In fact, I do the orientation assignment using python scripts. The orientation was assigned to an element set instead of a geometry set. For the assignment on geometry set, at least I can show the local coordinate system at Property-Tools-Query-Beam Orientations. It seems unable to show for the assignment on element set.
Thank you for your answer FEA way
I want to obtain a field of parameter trying to characterize nodals or elements stiffness in a simple approach. By simple approach I mean not trying to obtain the stiffness matrix. Now I come out a way of parameter=SF/U, SF and U are supposed to be in same direction. However the U and SF are not in the same direction. If U is in global coordinate, can I obtain the transformed U in the local coordinate.
And, please give any opinion on my approach?
Just notice the NFORC result. Is NFORC in global coordinate system? Then maybe I use NFORC/U is more appropriate?
You can transform the results to a common user-defined (local) coordinate system. But check the post titled "How to create stiffness (nodal force/displacement) contour plot using Python script in Abaqus?" on Stackoverflow too.
