abaqus problem_fictitious arrow
Tinni1
157
I am facing a strange problem in Abaqus.
I have a stud and track assembly model with two rigid plates at the top and bottom.
After doing the model I realized at I defined one surface as incorrect, while defining tie constraint in the interaction module and corrected the surface definition.
After doing this two arrows appeared in my model, and I am not understanding how this happened. They are not loaded, as they can be seen in the interaction module itself.
I reran the analysis and found no change in the result.
Could anyone provide any direction, what those arrows are and how I can remove them?
I have taken a screenshot[URL unfurl="true"]https://res.cloudinary.com/engineering-com/raw/upload/v1642093150/tips/Abaqus_fictitious_arrow_problem_tobbk5.docx[/url] for better understanding as attached.
Try suppressing subsequent features to see when these arrows disappear. Or go to symbol display settings and suppress the display of subsequent features there.
Great. Thanks for your response.
