Abaqus riks
ohdk
DE
Hello
I am using abaqus riks to represent a behavior of honeycomb structure under compression
I want to compress half of the total length of the structure for example I gave displacement 10, total height of honeycomb structure is 20. It is not simple honeycomb structure so I imported geometry. It is 3D solid. I used tetrahedral meshes.
I assume there will be a buckling so I used Riks method but the problem is maximum displacement I got is only 3 but I want to see this strcuture collapse more. Even though I increased displacement, it still converges to the displacement 3.
When I visulize this, I could see in the beginning of increment steps, it is really compressed but it stabilize at some points during rest of steps.
My question is that how can I make this strcuture compress more with larger displacement.
Thank you
I am not a structural engineer so I may be wrong but if you prescribed a displacement BC, then why would the structure buckle?
Are you new to this forum? If so, please read these FAQs:
Okay.. I prescribed a displacement on the top surface of the honeycomb structure and a displacement is pretty big enough to buckle, a displamcent is 50% of total height of the stucture
No. I am sure you did not understand what I am asking. It already started to buckle in a small displacement. What I want to know is that simulation is not converging to the displacement I gave.
Yes, you may be right in the sense I do not understand how something can *buckle* when *displacement* has been *prescribed* instead of a *load*. But I am no structural engineer so there's that. Or, may be I haven't understood what the 'real' question/issue is.
