Abaqus/Standard Analysis exited with an error
NEROOO
36
I submitted a job but got an error:
"Abaqus/Standard Analysis exited with an error - Please see the message file for possible error messages if the file exists."
And the message file :
STEP 1 INCREMENT 1 STEP TIME 0.00
S T E P 1 S T A T I C A N A L Y S I S
AUTOMATIC TIME CONTROL WITH -
A SUGGESTED INITIAL TIME INCREMENT OF 5.000E-02
AND A TOTAL TIME PERIOD OF 1.00
THE MINIMUM TIME INCREMENT ALLOWED IS 1.000E-06
THE MAXIMUM TIME INCREMENT ALLOWED IS 5.000E-02
LINEAR EQUATION SOLVER TYPE DIRECT SPARSE
CONVERGENCE TOLERANCE PARAMETERS FOR FORCE
CRITERION FOR RESIDUAL FORCE FOR A NONLINEAR PROBLEM 5.000E-03
CRITERION FOR DISP. CORRECTION IN A NONLINEAR PROBLEM 1.000E-02
INITIAL VALUE OF TIME AVERAGE FORCE 1.000E-02
AVERAGE FORCE IS TIME AVERAGE FORCE
ALTERNATE CRIT. FOR RESIDUAL FORCE FOR A NONLINEAR PROBLEM 2.000E-02
CRITERION FOR ZERO FORCE RELATIVE TO TIME AVRG. FORCE 1.000E-05
CRITERION FOR RESIDUAL FORCE WHEN THERE IS ZERO FLUX 1.000E-05
CRITERION FOR DISP. CORRECTION WHEN THERE IS ZERO FLUX 1.000E-03
CRITERION FOR RESIDUAL FORCE FOR A LINEAR INCREMENT 1.000E-08
FIELD CONVERSION RATIO 1.00
CRITERION FOR ZERO FORCE REL. TO TIME AVRG. MAX. FORCE 1.000E-05
CRITERION FOR ZERO DISP. RELATIVE TO CHARACTERISTIC LENGTH 1.000E-08
VOLUMETRIC STRAIN COMPATIBILITY TOLERANCE FOR HYBRID SOLIDS 1.000E-05
AXIAL STRAIN COMPATIBILITY TOLERANCE FOR HYBRID BEAMS 1.000E-05
TRANS. SHEAR STRAIN COMPATIBILITY TOLERANCE FOR HYBRID BEAMS 1.000E-05
SOFT CONTACT CONSTRAINT COMPATIBILITY TOLERANCE FOR P>P0 5.000E-03
SOFT CONTACT CONSTRAINT COMPATIBILITY TOLERANCE FOR P=0.0 0.100
CONTACT FORCE ERROR TOLERANCE FOR CONVERT SDI=YES 1.00
DISPLACEMENT COMPATIBILITY TOLERANCE FOR DCOUP ELEMENTS 1.000E-05
ROTATION COMPATIBILITY TOLERANCE FOR DCOUP ELEMENTS 1.000E-05
EQUILIBRIUM WILL BE CHECKED FOR SEVERE DISCONTINUITY ITERATIONS
TIME INCREMENTATION CONTROL PARAMETERS:
FIRST EQUILIBRIUM ITERATION FOR CONSECUTIVE DIVERGENCE CHECK 4
EQUILIBRIUM ITERATION AT WHICH LOG. CONVERGENCE RATE CHECK BEGINS 8
EQUILIBRIUM ITERATION AFTER WHICH ALTERNATE RESIDUAL IS USED 9
MAXIMUM EQUILIBRIUM ITERATIONS ALLOWED 16
EQUILIBRIUM ITERATION COUNT FOR CUT-BACK IN NEXT INCREMENT 10
MAXIMUM EQUILIB. ITERS IN TWO INCREMENTS FOR TIME INCREMENT INCREASE 4
MAXIMUM ITERATIONS FOR SEVERE DISCONTINUITIES 50
MAXIMUM ATTEMPTS ALLOWED IN AN INCREMENT 5
MAXIMUM DISCON. ITERS IN TWO INCREMENTS FOR TIME INCREMENT INCREASE 50
MAXIMUM CONTACT AUGMENTATIONS FOR *SURFACE BEHAVIOR,AUGMENTED LAGRANGE 50
CUT-BACK FACTOR AFTER DIVERGENCE 0.2500
CUT-BACK FACTOR FOR TOO SLOW CONVERGENCE 0.5000
CUT-BACK FACTOR AFTER TOO MANY EQUILIBRIUM ITERATIONS 0.7500
CUT-BACK FACTOR AFTER TOO MANY SEVERE DISCONTINUITY ITERATIONS 0.2500
CUT-BACK FACTOR AFTER PROBLEMS IN ELEMENT ASSEMBLY 0.2500
INCREASE FACTOR AFTER TWO INCREMENTS THAT CONVERGE QUICKLY 1.500
MAX. TIME INCREMENT INCREASE FACTOR ALLOWED 1.500
MAX. TIME INCREMENT INCREASE FACTOR ALLOWED (DYNAMICS) 1.250
MAX. TIME INCREMENT INCREASE FACTOR ALLOWED (DIFFUSION) 2.000
MINIMUM TIME INCREMENT RATIO FOR EXTRAPOLATION TO OCCUR 0.1000
MAX. RATIO OF TIME INCREMENT TO STABILITY LIMIT 1.000
FRACTION OF STABILITY LIMIT FOR NEW TIME INCREMENT 0.9500
TIME INCREMENT INCREASE FACTOR BEFORE A TIME POINT 1.000
GLOBAL STABILIZATION CONTROL IS NOT USED
PRINT OF INCREMENT NUMBER, TIME, ETC., EVERY 1 INCREMENTS
THE MAXIMUM NUMBER OF INCREMENTS IN THIS STEP IS 1000
LARGE DISPLACEMENT THEORY WILL BE USED
LINEAR EXTRAPOLATION WILL BE USED
CHARACTERISTIC ELEMENT LENGTH 1.00
DETAILS REGARDING ACTUAL SOLUTION WAVEFRONT REQUESTED
DETAILED OUTPUT OF DIAGNOSTICS TO DATABASE REQUESTED
PRINT OF INCREMENT NUMBER, TIME, ETC., TO THE MESSAGE FILE EVERY 1 INCREMENTS
COLLECTING MODEL CONSTRAINT INFORMATION FOR OVERCONSTRAINT CHECKS
COLLECTING STEP CONSTRAINT INFORMATION FOR OVERCONSTRAINT CHECKS
INCREMENT 1 STARTS. ATTEMPT NUMBER 1, TIME INCREMENT 5.000E-02
I didn't find any error in there, looking for some help!
Thanks a lot!
This file is incomplete. If this is the whole file then it seems the solver exited unexpectedly without even an error.
See if there is a .log file with an error message.
Can you provide some details about the analysis ? Such ambiguous error messages may be caused by issues independent of Abaqus but also by mistakes in modeling.
Also check the dat file for warnings/errors.
