abaqus_beginner
Student
Hi, I am new in FEM Model. I need to do a static analysis for skid frame model. Before that, I have to create the mesh model. My supervisor said that the mesh model needs to be continued, including for two separated surface. The problem is my structure has a complex geometry, so it is hard to fuse together all separate surface. Is it enough if I just use tie constraints to replace the continued mesh model? Or will it give a significant difference in results?
