Abaqus USDFL
surotm
MY
Dear all,
I have a problem. I want to create a rather simple script (USDFL) that changes material properties (such as Young's modulus) in the whole part after detecting an alarm, for instance, reaching a certain level of strain in a single FE. The problem is when I use scripts I found online, the change occurs only in a single material point (single FE), not in the entire part (all FEs). Can you help?
UBROUTINE USDFLD(FIELD,STATEV,PNEWDT,DIRECT,T,CELENT,
1 TIME,DTIME,CMNAME,ORNAME,NFIELD,NSTATV,NOEL,NPT,LAYER,
2 KSPT,KSTEP,KINC,NDI,NSHR,COORD,JMAC,JMATYP,MATLAYO,
3 LACCFLA)
C
INCLUDE 'ABA_PARAM.INC'
C
CHARACTER*80 CMNAME,ORNAME
CHARACTER*3 FLGRAY(15)
DIMENSION FIELD(NFIELD),STATEV(NSTATV),DIRECT(3,3),
1 T(3,3),TIME(2)
DIMENSION ARRAY(15),JARRAY(15),JMAC(*),JMATYP(*),
1 COORD(*)
C
C Absolute value of current strain:
CALL GETVRM('E',ARRAY,JARRAY,FLGRAY,JRCD,JMAC,JMATYP,
MATLAYO,LACCFLA)
EPS = ABS( ARRAY(1) )
C Maximum value of strain up to this point in time:
CALL GETVRM('SDV',ARRAY,JARRAY,FLGRAY,JRCD,JMAC,JMATYP,
MATLAYO,LACCFLA)
EPSMAX = ARRAY(1)
C Use the maximum strain as a field variable
FIELD(1) = MAX( EPS , EPSMAX )
C Store the maximum strain as a solution dependent state
C variable
STATEV(1) = FIELD(1)
C If error, write comment to .DAT file:
IF(JRCD.NE.0)THEN
WRITE(6,*) 'REQUEST ERROR IN USDFLD FOR ELEMENT NUMBER ',
1 NOEL,'INTEGRATION POINT NUMBER ',NPT
ENDIF
C
RETURN
END
This subroutine only calculates the maximum strain and stores it as a solution-dependent state variable. How do you realize the second part - changing material properties ? Can you share the input file or at least part of it ?
Sure, below you can find the inp and for files.
### INP ###
*Heading
** Job name: Job-2 Model name: Model-1
** Generated by: Abaqus/CAE 2020.HF11
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=Part-1
*Node
1, 0., 0., 0.
2, 0.0166666675, 0., 0.
3, 0.0333333351, 0., 0.
4, 0.0500000007, 0., 0.
5, 0.0666666701, 0., 0.
6, 0.0833333358, 0., 0.
7, 0.100000001, 0., 0.
*Element, type=B31
1, 1, 2
2, 2, 3
3, 3, 4
4, 4, 5
5, 5, 6
6, 6, 7
*Nset, nset=Set-1, generate
1, 7, 1
*Elset, elset=Set-1, generate
1, 6, 1
*Nset, nset=Set-3, generate
1, 7, 1
*Elset, elset=Set-3, generate
1, 6, 1
** Section: Section-1 Profile: Profile-1
*Beam Section, elset=Set-1, material=Material-1, temperature=GRADIENTS, section=RECT
0.01, 0.01
0.,0.,-1.
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=Part-1-1, part=Part-1
*End Instance
*Nset, nset=Set-1, instance=Part-1-1
1,
*Nset, nset=Set-2, instance=Part-1-1
7,
*End Assembly
** MATERIALS
*Material, name=Material-1
*Depvar
1,
*Elastic, dependencies=1
2e+11, 0.3, , 0.
1e+11, 0.3, , 1.
*User Defined Field
** BOUNDARY CONDITIONS
** Name: BC-1 Type: Displacement/Rotation
*Boundary
Set-1, 1, 1
Set-1, 2, 2
Set-1, 3, 3
Set-1, 4, 4
Set-1, 5, 5
Set-1, 6, 6
** STEP: Step-1
*Step, name=Step-1, nlgeom=YES, inc=1000
*Static
0.1, 1., 1e-05, 0.1
** LOADS
** Name: Load-1 Type: Concentrated force
*Cload
Set-2, 2, -1000.
Set-2, 3, 0.
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
### FOR ###
SUBROUTINE USDFLD(FIELD,STATEV,PNEWDT,DIRECT,T,CELENT,
2 KSPT,KSTEP,KINC,NDI,NSHR,COORD,JMAC,JMATYP,MATLAYO,LACCFLA)
C
C
DIMENSION FIELD(NFIELD),STATEV(NSTATV),DIRECT(3,3),T(3,3),TIME(2),
* coord(*),jmac(*),jmtyp(*)
PARAMETER (ONE=1.0D0)
CALL GETVRM('S',ARRAY,JARRAY,FLGRAY,JRCD,JMAC,JMATYP,MATLAYO,LACCFLA)
S11 = ARRAY(1)
Alarm=250000000.0D
FIELD(1)=0
CHECK=(S11/Alarm)
IF (CHECK > 1.0D) THEN
FIELD(1)=1
statev(1)=CHECK
END IF
RETURN
END
It looks fine. Did you check the outputs used by this subroutine - SDV and maximum strain to make sure that everything works correctly on that side ? How do you know that only one element is affected ?
