Hello everyone!
I am working on a project that requires the use of hyperelastic material. Therefore, I intend to utilize biaxial test data to define the hyperelastic material.
However, I am uncertain about the data I should provide. The biaxial data consists of experimental tests with nominal stress/strain curves along two directions. In Abaqus CAE, there is only one column designated for nominal stress (and nominal strain) (see attached).
Should I use the "global" nominal stress (a combination of the two directions) or do I need to choose one of my two directions? And in these cases, what is the difference between providing uniaxial data?
Thank you very much for your help.
Best regards,
Best regards,
