Abaqus versions compatibility 1
hwa0725
18
Hi all,
In my local PC, I have had Abaqus/2019 installed and used it to construct my model, however, I am running the analysis on a higher version i.e. Abaqus/2023. I know this is ok as Abaqus is backwards compatible also as mentioned here by FEAWay (
So my question is: Can I open the .odb ran on Abaqus/2023 with Abaqus/2019 installed on my PC to post-process the analysed model?
Many thanks!
Heng
No, this would be forward compatibility (older version handling files from newer version) which is not available in Abaqus.
